Changing power steering fluid
Old May 4, 2007 | 10:30 PM
OzarksFord's Avatar
OzarksFord
If I want to change out the fluid in my power steerting pump/system, do I just drain the resoirovoir? How much fluid is in the lines? How do I drain the lines?
Old May 5, 2007 | 12:41 AM
kermmydog's Avatar
kermmydog
You can disconnect the return line route it into a bucket. Then start & turn the wheel slowly. Add fluid until you get clean fluid coming out the return. Reconnect the return line top off and your good.
Old May 5, 2007 | 01:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Add a filter in the return line after you have done the above. The fluid coming out of the container is not really clean enuf. Ford uses an initial fill with filtered fluid.
Wix Transmission/PS Filter
Wix transmission/PS filter #58964
Ford equivalent filter kit #XC3Z-7B155-AA
Ford filter alone #XC3P-7B155-BA
200 psi working, pressure relieved, magnetic
change yearly or 12000 miles
For more info on fluid changes etc try post #9 here:
https://www.ford-trucks.com/forums/1...ease-read.html
Old May 5, 2007 | 04:06 PM
OzarksFord's Avatar
OzarksFord
I have a metal line coming from the side of the pump to the steering box. Another metal line with a rubber hose goes to the back of the power steering pump. Which is the return line?
Old May 5, 2007 | 05:07 PM
ri_truck_guy's Avatar
ri_truck_guy
The rubber hose is the low pressure return line.
Bill
86 F150 4x4 5.0
Old May 7, 2007 | 08:41 AM
OzarksFord's Avatar
OzarksFord
If I remove the return hose and start dumping clean fluid into the pump, will the clean fluid drain out of the pump through where the return hose connects of is this a one way route? Do I need to cap off the port where the return hose connects to the pump until I am through adding clean fluid?
Old May 7, 2007 | 10:19 AM
Sport45's Avatar
Sport45
You need to cap that port. If you don't have a plug that size just connect a hose to the port and run it to a location higher than the fill port.
