computer
Old May 4, 2007 | 05:58 AM
ian24328's Avatar
ian24328
Question computer
can anyone tell me if a computer from a 87-93 5.0 mustang will fit a 1992 f150 4x4 with a 5.0 mustang engine someone said it would fit plus may get my mpg back up, Thanks, Dewayne
Old May 4, 2007 | 06:06 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It'll fit, but you won't like the way it runs, if it runs at all. Engine components are matched to the original computer. Changing the computer brings on all sorts of problems. You don't want to consider making this change.
Someone once said the earth was flat, too. "Someone said" gets ppl into all sorts of trouble.
Old May 4, 2007 | 06:17 AM
ian24328's Avatar
ian24328
can you tell what would help on fuel mpg it has mustang headers with a flow master single pipe no cat 5 speed 4x4 12 to 13 mpg thats all, Thanks
Old May 4, 2007 | 06:20 AM
taisa899's Avatar
taisa899
are you running the 351 firing order with the Mustang motor? If not you should be
Jim
Old May 4, 2007 | 06:23 AM
ian24328's Avatar
ian24328
yes running that order Thanks,
Old May 4, 2007 | 07:11 AM
frederic's Avatar
frederic
Gearing and driving habits will give you the most fuel mileage change. I reguarly get 15-16ish in my 93 F350 crewcab, which weighs a lot more than your truck. Mine's a stick so I control the shift points obviously, and unless I'm merging on a highway (or towing, or heavily loaded), I'm in overdrive by 30-35 mph.
Headers, if they're a good design, usually give better mileage because they restrict the exhaust flow less than the stock manifolds. That's assuming the "cork" behind them is changed also - the cork is not necessarily the muffler or the cat, but mostly the inlet/outlet diameters of both as well as the diameter of the exhaust tubing throughout.
Old May 4, 2007 | 04:10 PM
EPNCSU2006's Avatar
EPNCSU2006
You would have to do a lot of re-wiring to get the computer to work, but yes, it will run the engine in the truck. That computer is what Ford uses in the popular mass air conversion kits.
