1978 - 1996 Big Bronco
78 bronco rear leaf spring codes
Old Mar 20, 2001 | 03:09 PM
dallan's Avatar
dallan
could someone please tell me where i can find these codes? i have a '78 in need of new rear springs. i would like to keep it as close to stock as possiable. anyone who is using the k bar s heavyduty ones have any comments on them?
thanks
djallan@telusplanet.net
Old Mar 20, 2001 | 05:42 PM
Bob_VT's Avatar
Bob_VT
Call a spring shop. I just replaced mine with a set from a 3/4 ton, they are stiff but they were 1/2 the money. JC Whitney can also supply springs for the 78 Bronco in stock configuration. Be prepared to use a cutting torch to remove the old sleeves and bushings. They tend to rust in and have to be cut out. I would suggest that you also replace the rear spring hanger (swing) brackets.
Old Apr 9, 2001 | 02:42 PM
dallan's Avatar
dallan
thanks for responding bob. i would have said thanks sooner but i crashed my computer, thank god not my bronco, anyways i contacted my local springshop and they wanted the codes? they looked on my door jam at the plate and couldn't find the information. i went to the ford dealer and he can't figure out why mine doesnt have the info on that plate. he didn't even have luck trying to look it up. I might just go with the springs from k bar s.
thanks,
dave
Old Apr 9, 2001 | 03:57 PM
Bob_VT's Avatar
Bob_VT
Check this web site www.youngspring.com this is the local spring shop that I use and I trust this mans judgement and advice. He would probably look up the numbers you need if you call him.
I had the chance to haul over 1200 lbs of steel in the back of the bronco and I still had plenty of spring left. I have to admit that the 3/4 ton springs are stiff but that was my choice.
Old Apr 10, 2001 | 10:17 AM
ford motorsports's Avatar
ford motorsports
I have a 78 Bronco, and I have the saggy spring problem, I was wondering if you could swap some newer style (87-96) f-150 spings and still have the ride quality. I have been contemplating this for a while. I also have a 4 inch lift.
Old Apr 10, 2001 | 02:34 PM
1911bronco's Avatar
1911bronco
hey Dallan...You might want to check around locally for another shop...I went to a welder/fabricator shop...and they had a book that showed standard and heavey duty springs for my 79 bronco...I got the heavey duty springs....It was actually cheaper than Whitley...not even counting shipping.
good luck
Old Apr 10, 2001 | 06:14 PM
Bob_VT's Avatar
Bob_VT
