1978 - 1996 Big Bronco
open diff. or Trac Lock?
Old Jan 8, 2012 | 05:59 PM
v8only's Avatar
v8only
if you plan on doing any moderate wheeling such as what I posted above, a true locker is the only way to go. You have many choices....the detroit locker is an extremely popular choice..on the budget end of things, you can buy a lockright locker for around $250 and it goes right into your existing open diff....if you aren't running huge tires or massive HP, that also seems to be a popular choice
Old Jan 8, 2012 | 06:51 PM
Edgethis's Avatar
Edgethis
Detroit (Eaton) makes a locker.
Detroit Locker Differentials
Detroit Locker 187C145A - Eaton Detroit Lockers - Overview - SummitRacing.com
Ford 8.8" Detroit Locker
Old Jan 8, 2012 | 07:05 PM
njneer1's Avatar
njneer1
Traclock or any other limited slip WILL NOT work with one wheel off the ground.....only a locker works in that condition. You must have at least some resistance for a LS to work
Old Jan 8, 2012 | 07:55 PM
ErrorS's Avatar
ErrorS
that's why feathering the brakes help, I think it's an old school trick. Just kick on the e-brake a few clicks and it can help you if you're doing the one wheel spin.
I think i'm gonna stick with limited slip, lockers are too fricken expensive and I'm never going to wheel hard enough to use one. The only way I'd slap one in is if it were select-able. Plus, that's a scary amount of force not being transferred if one wheel binds, which happens all the darn time offroad. tight LS in the rear plus a limited slip in the front should handle anything but the deepest mud and the most hardcore of rock crawling in my humble opinion.
slap in a locker and you crossed that sometimes fine line into turning your truck into just a trail rig
Old Jan 8, 2012 | 07:59 PM
Nighteyez's Avatar
Nighteyez
Active Streak: 30 Days
Hence, putting your foot on the brake to add resistance. that makes sense. Since my diff is an open one, I guess getting a limited slip is a step up, but if I am going to spend that kind of money, I might as well buy the Detroit Locker. However, I will not do mudding, or rock crawling, so I am wondering if that might not be a bit of overkill. Especially since this is a daily driver. The LS would be better for the pavement. Still for the price, you can't beat having a true locker.
Jim
Old Jan 8, 2012 | 08:02 PM
ErrorS's Avatar
ErrorS
Broncograveyard has some better and tighter LS units closer to lockers on their site, I'll probably go that route if I decide my carrier needs an upgrade. I think they're like half the price of a locker.
Old Jan 8, 2012 | 08:09 PM
Nighteyez's Avatar
Nighteyez
it is a moot point for me at the moment as I will not be buying anything that expensive for my truck for at least a year. Still, would be nice to know which way to go. So when I do get the money I will have a plan.
Jim
Old Jan 8, 2012 | 08:57 PM
njneer1's Avatar
njneer1
I wheel hard enough for the locker !! Gonna try the Powertrax or lockright
Old Jan 8, 2012 | 09:03 PM
Nighteyez's Avatar
Nighteyez
For $250, you can't go wrong. maybe I'll get that instead of spending $600-700 on the Eaton.
Jim
Old Jan 9, 2012 | 11:32 AM
ErrorS's Avatar
ErrorS
It's the Yukon, everywhere I've read on the internet says they're great. Plus, you can't beat a Bronograveyard endorsement, these guys have never steered me wrong or sold me a less-than quality part, ever.
Yukon DuraGrip Ford 8.8", 31 spline
Old Jan 9, 2012 | 11:58 AM
Nighteyez's Avatar
Nighteyez
Half the price works for me.
Jim
Old Jan 9, 2012 | 06:02 PM
Edgethis's Avatar
Edgethis
I think I will look into that once I get the Zebra running again.
E350John
26
Nov 23, 2017 09:52 PM
03-F150
1997 - 2003 F150
May 1, 2015 11:32 PM
96_F250_Deezal
Feb 5, 2012 11:06 PM
ekuhn
1983 - 2012 Ranger & B-Series
Dec 25, 2010 09:58 AM
03-F150
Oct 13, 2006 02:09 PM
