I recently solved my overheating problem. The PO had installed an engine fan incorrect for the engine rotation so it "pushed" instead of pulled. The Rad was also leaking. A correct engine fan wouldn't have solved the problem because the 302 sat so low in the engine bay that the fan was only about 2/3 on the radiator core. Couldn't get a bigger fan because the lower rad hose limited how big the diameter of the fan could be.
So, I got a new radiator, bought an electric fan with temperature control from FlexaLite and used it as my primary.
Problem solved for me.
Radiator clogged, incorrect radiator for V-8, Fan belt loose, Missing fan shroud, incorrect fan, incorrect water pump,fan blades bent by PO, idles to slow, a/c or tranny radiators blocking air flow. Aft side pull elect fans are best, but you could ad a push elect fan in front of radiator if everything else is ok. Things to consider. Have a great day, chuck
I have a 1956 F100 with a 272 V8 engine. I have a problem with it running hot. Has anyone had this problem and what did you do to fix it?
As Chuck stated there are many variables to consider when trying to determine the reason for running hot. As a general rule if it's running hot at idle the problem is insufficient air flow (no shroud, fan too small, fan not close enough to radiator, not enough blades, fan diameter too small, etc.). If you can place a piece of paper on the front of the radiator while the engine is running and it stays there then you probably have sufficient air flow. If it runs hot on the highway at speed then the problem is more likely a lack of circulation in the radiator due to rust and corrosion or possibly not enough capacity if you are not running the original radiator. Is this a new problem or an old one? Even the engine timing can affect engine temperature adversely.
Right before I had my 292 completely rebuilt, I took it apart and noticed that the block (water jacket) was fairly clogged up with dirt/rust/sand/etc.
These engines are very old. Some people didn't flush engines and radiators very well in the "old days". And even then, flushing doesn't get it all out. If half of the radiator tubes are plugged, your radiator may only be 1/2 as effective.
A sticky thermostat could be the problem, but they almost never fail. (they do, just not often) If you suspect the thermostat remove it and stick it in a pan of water on the stove and see if(when) it opens. (do it when you wife is away and you won't get yelled at!)
This last weekend I thought my 272 was running hot out on the freeway. At least according to the temp gauge. When I got home I shot it with my infared temp gun. 182*
The dash gauge showed it way over passed the P in TEMP/ .
