rear axle identification
Old 05-03-2007, 02:55 PM
fulltimehiboy's Avatar
fulltimehiboy
fulltimehiboy is offline
hey guys, looking for some help fing out what model my rear axle is. I have a 1977 f250 hiboy built 1/77 6.6L c-6 full time four wheel drive. The rear axle tag rotted off my cover. I tried to gently clean the housing for the other codes. The rust got the best of it. I pulled the cover off and have the numbers off the ring gear: 10 22 76 DANA 30363 b3r45x 41 10. On the inside of the case is: 2 60 hd. The door tag is blank for axle code but the rear axle rating is :3950. The other night i found a link for a site from dana. I should have booked mark it because i can not find it today.
thank you,
ken
Old 05-03-2007, 03:00 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
See this page and get the bill of material number.
http://www.lightruck.com/axle_parts_rings.asp
http://www2.dana.com/pdf/X510-8.PDF
Old 05-03-2007, 03:05 PM
fulltimehiboy
I could not find the bill of material number on the tube. The rust got to it before i did. I could not find the model number either.
Old 05-03-2007, 03:07 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Click the 2nd link in post above and look up the ring gear.
or count the number of splines on the ring gear and pinion gear and just do the math
Old 05-03-2007, 03:27 PM
fulltimehiboy
i know it is a 4.10 ratio. The ring gear had 41 teeth and the pinion had 10.
I just want be sure of the model before i order a locker.
Old 05-03-2007, 03:30 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
thank you,
ken
Every F250 sold in the 1970's had a rear axle capacity of 5300 lbs., 4 WD or 2WD. There's no listing in the Ford parts catalog for 3950 lbs for any F250. Two rear axles were used in 1977 F250's, Dana 61-1 or Dana 60. None of the above numbers can be translated by using the parts catalog. This I know: 41 10 is 4.09; or 4.10; or 4,11-1. Look on the axle tubing for a stamped Dana ID number, it's 6 numbers with/without a letter suffix. The original axle tag was rectangular in shape, on the left side of the housing adjacent to the cover, and held on by two bolts.
Old 05-03-2007, 03:38 PM
fulltimehiboy
thanks bill, i am going to my garage after dinner. I will clean the tubes more to find the numbers but i think they are gone. On the inside of the case had 2 60 hd near the pinnion.
Old 05-03-2007, 04:06 PM
NumberDummy
Number would be difficult to be missing, the Dana ID number is stamped into the axle tube (parts catalog doesn't say where). Look again on the door tag, Ford didn't always stamp the codes where they are supposed to be. The axle codes is three digits, the tranny one. They may all be stamped together. If the rear axle on your F250 4x4 is the original, it will be a Dana 60. It's also possible the door has been changed, but the original VIN wasn't swapped over. A 3900 rear axle capacity is F150 or E150 territory, not an F250. 3900lbs would be (in your case) a Dana 44. Dana 44 has a 10 bolt rear cover, a Dana 60 has a 9 bolt rear cover. What are the first three digits of the door tag VIN?
Old 05-03-2007, 04:18 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Bill... my Link shows the location of all the ident spots.
One has to actually click the link to see it.
Old 05-03-2007, 04:32 PM
fulltimehiboy
the first 3 of the vin are f26. There was a out of place set of numbers fo250/to736. Are these these the axle and tranny code?
Old 05-03-2007, 04:35 PM
fulltimehiboy
I am almost positive there were 10 bolts on the cover and 12 on the ring gear. Someone else told me that the f250's always had 60's in the rear.
Old 05-03-2007, 04:42 PM
NumberDummy
73 = Dana 60 / 4.10-1 / 5050lb Rear Axle Capacity
6 = ? no reference in parts catalog, maybe Mil1ion knows.
Parts catalog shows the Dana 61-1 for a F250, too...but I doubt that axle will be seen on a 4X4 of this vintage.
Now I wonder what the trans code is. F (o-?) 250 is F250 / C6 trans code is: G or Z (and X but used for fleet sales only)
VIN: F26 is F250 4X4.
Old 05-03-2007, 04:51 PM
fulltimehiboy
So it is a 60 rear bill? It is weird that the door says 3950 for the rear rating. The truck was for a fire dept most of it's life so over all it's in pretty good shape for upper ny. the box was repaired poorly but picke up a nice one from jersey that needs minimal work. I can not wait to get a locker in the rear. I shouldn't have to be as hard on it pulling fire wood out of the hills. I am going back to my garage to check the numbers again. Thank you for your guys help.
Old 05-03-2007, 04:53 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
There isn't anything in the VIN# regarding axles or transmissions.
see the VinDecoder on my web page to see how things are stamped on the rating plate.
http://www.clubfte.com/users/mil1ion...ruckCodes.html
Old 05-03-2007, 04:57 PM
NumberDummy
Dana 60 it is...or at least that's what the door tag axle code is. What's in there now? Prolly a Dana 60, but I'd still look for the stamp number...Mil1ion posted a pic showing where it is.
Fire Dept? Well heck, that explains it..all FD vehicles were special ordered as a general rule. Look on the VIN plate again, see where it says DSO? What are the numbers?
I asked for the VIN first 3 digits to see if the three number pertained to a F250 4X4, and they do. I also asked the question to see if door tag was the correct one. The F26 is correct. The actual VIN (Vehicle ID Number) doesn't have axle or trans codes, but the Rating or Warranty (VIN) Plate does, because that's where the codes are.
Dennis, I know what VIN's pertain to, after 35 years behind a Ford Parts counter, I'd better.
Quick Reply: rear axle identification
