Bill, the dso code is blank where numbers should be. I spent another hour trying to take rust off the axle tube to find the numbers but no luck. I found in the glove box a waranty identification card on the bottom of the card it has a metal tag with the these numbers: F26sex81409 N K 13
F260 4 24J G
I know the first set is the vin after that i'm clueless
maybe dennis. There is no plate on the door, there is a sticker on the b pillar. the vins match even the waranty identification card i found. Maybe it was made on a friday at beer thirty.
F260 4 24J G
Does the VIN on warranty card match your registration? I decoded another FD VIN, the truck was a F600, the warranty card in the glove box was for a C Series = Cab Over.
In other words, the warranty card may be for something else. Verify VIN on card with your registration...see if it matches door tag!
Out of place G code could refer to transmission. G is the code for a C6.
Truck was prolly built on the first shift on a Monday. Workers were hung over after heavy night of drinking. Local high school team finally won a game of chinese checkers after 80 years of trying.
