motor mount
Old May 3, 2007 | 01:40 PM
someday's Avatar
someday
motor mount
my 89 f350 has a broken motor mount on a 460 2wd c6...it looks impossible to change...what do i have to remove, loosen to get to the bolts and change? should i disconnect any wires and/or hoses, maybe even driveshaft? how long should it take and should i change all of them?
Old May 4, 2007 | 10:22 PM
nighthawk285's Avatar
nighthawk285
is the rubber broke, or the mount to the crossmember/engine broke? whatever happens, you'll have to loosen everything enough to raise and support that engine enough to get it off the mounts and leave room to work
