1978 - 1996 Big Bronco
83 Transmission ID
Old Apr 27, 2001 | 01:38 PM
ronbo862's Avatar
ronbo862
83 Transmission ID
Hi all, new to the forum and I want to put your knowledge to good use I have an 83, 4.9L 4WD with a bad clutch. I have IDd the transfer case as a NP 208 but the 4 speed I cannot figure out. The ID tag on it says that it is a RUG but when I look in my repair manual for removal instructions it tells me to "disconnect clips and remove shift rods". Ok, there are none, the shifter is bolted to a casing which in turn is bolted to the tranny. I dont want to pull this apart and have the guts inside fall out. Can any one tell me which tranny I have? Its a 4-speed overdrive. If it is an actual RUG, how do I remove the shifter? Thanks for any guidance you can give!!
Ron
Old Apr 27, 2001 | 08:44 PM
thelonerangerxlt's Avatar
thelonerangerxlt
83 Transmission ID
Ronbo, you do have a RUG transmission. I beleive it's made in Germany. The shifter just unbolts from the top of tranny. Be sure and watch how it comes out, and have it in neutral when removing. Best I can remember, it's a no brainer, nothing will spring out at you or anything.
"Nothing lasts forever except natural stone and old Ford trucks." (Willie Nelson)
Old Apr 28, 2001 | 11:54 AM
ronbo862's Avatar
ronbo862
83 Transmission ID
Thanks a bunch! I just spent the last week under the truck looking at the transfer case and yesterday I finally wrestled it out. I dont want to spend the next week looking at the tranny and wondering I'll pop that puppy out today and get on with it, again thanks!
Ron
Old Apr 28, 2001 | 11:48 PM
hotrodford_88's Avatar
hotrodford_88
83 Transmission ID
Ztitan
55
Mar 31, 2021 10:48 AM
kupiec20
Nov 12, 2009 08:03 AM
flyhound
Dec 15, 2003 12:21 AM
ClatonK
Nov 24, 2003 08:03 PM
