1978 - 1996 Big Bronco
??? about 5.0 engines
Old Apr 4, 2001 | 03:48 AM
rywegh's Avatar
rywegh
I have an 88 bronco. The engine needs work. Is it on its last legs not sure till I tear it apart. hoping its just bad head gaskits. If the block is bad I have a 5.0 out of a 85 Lincoln. After parts were machined would I be able to put the two engines together? Namely 88-heads,intake to 85-block. Any special work or notes? Just waiting on time and some more cash to get to it. Any help is appreciated.
Old May 3, 2001 | 11:24 PM
wheelspin's Avatar
wheelspin
The blocks should be the same. Use the later e7te castings, they are much better than the previous. I would also convert to a roller cam. They sell a conversion kit or just use an 87' later ho block. But that's just hmo.
Old May 4, 2001 | 05:50 AM
AlM's Avatar
AlM
