Stage 1 Cold Air Intake System Type EZ with Pro-Dry S
Ford Trucks (05-06) V10-6.8L
Oil-free 2-layer synthetic media
Increased air flow upto 50% for better performance
Increases horsepower & torque
Improces Fuel economy
99.4% efficient** for excellent protection
Wire mesh for structural integrity & quality
Convenient quick & easy cleaning
Increases horsepower up to 25 HP depending on application
Improves torque up to 35 lbs/ft depending on application
Maximizes airflow for better acceleration and responsiveness
Improved performance results in greater fuel efficiency
Installs in less than 45 minutes using factory mounting points
No cutting or drilling to engine compartment is required
Replaces OE air filter with high flow high performance 360 degree radial flow air filter
Washable/reusable air filter with the deepest pleats in the industry is the largest possible in the space allowed
Replaces factory air box with a heat-blocking shield that seals to the hood
Retains factory intake tube
Limited lifetime warranty
actual rear wheel HP gains come no where close to the box advertising! i think it was FRED who posted his gains with a K&N filter compared to a stock filter. there was a 5-7hp gain with the K&N filter.
the V10's intakes are not restrictive compared to the older models, or a car intake tube!!
save your $ get a good filter (dry or oil) and put that extra money into gas!! you might notice alittle difference but it woun't be 25HP difference!
Geez Louise! Where do they come up with that stuff?! 25/35 over stock with a filter change. Wonder what "application" they're talking about!? Must be the "application" that came with a sock stuffed in the intake tube...
