window motor
Old May 2, 2007 | 05:24 PM
royallenz06's Avatar
royallenz06
window motor
88 f150 xlt lariat
the passenger side window motor locked up this weekend so i went to the junkyard to find another one, no such luck. does anyone know where i could possibly find a cheap window motor or if out a differnet vehicle is compatible. thanks the cheapest one i can find is around 60 bucks. i dont wanna spend so much if i dont hafta.
Old May 2, 2007 | 09:12 PM
Conanski's Avatar
Conanski
The plastic rollers in the gear box are the common failure mechanism on these, if actual electrical motor or bearing are not shot it's an easy and dirt cheap fix, the rollers are available on ebay.. http://cgi.ebay.ca/Ford-E150-E250-E3...QQcmdZViewItem
Old May 3, 2007 | 04:16 AM
ncranchero's Avatar
ncranchero
.or Ford
D0AZ-62234A24-B .. Gear Kit ~ Power Window Motor ~ All cars from 1970; Trucks from 1980.
Old May 3, 2007 | 04:35 AM
Torque1st's Avatar
Torque1st
Posting Legend
Your local hardware store probably has 3/8" or 10MM ball bearings. Clean out the broken plastic, clean off the gears, relubricate the parts with synthetic brake caliper grease. Drop 3 ball bearings into the mechanism, reassemble and you are good. Motor removal usually involves drilling out rivets and making access holes in the door inner panel.
Old May 3, 2007 | 05:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by ncranchero
.or Ford
Hmmm, where have I seen that info before.
The Ford part number can be used at autoparts stores, where the kits are also available. The parts stores type in the Ford number into their computers, which gives them the number they are selling them under.
If the autoparts stores ask: "Which one do you want, the early or late kit?" Tell them the LATE kit. The early kit (C9AZ-62234A24-A) was only used on 1965/69 passenger cars.
Old May 3, 2007 | 02:19 PM
ncranchero's Avatar
ncranchero
I solly bloss ! I pass on goooo inflo.......
