Offroad & 4x4
SAS lift?
Old May 2, 2007 | 11:41 AM
nighthawk285's Avatar
nighthawk285
SAS lift?
In getting ready for this summers project, I've found out a lot from you guys and I appreciate it. One thing that I haven't found out, is once you do an SAS, do you buy a lift for the rig that you got the solid front axle out of, or do you buy one for your rig, or do you split it and get the rear springs for your rear, and the front equipment using the donor rig's stats. This is for my 87 F150 BTW, doing a D44 SAS, and I want about 6" of lift......enough to clear 35s with some good articulation for trails
Old May 2, 2007 | 12:34 PM
kjett's Avatar
kjett
Buy the springs for the SAS axle in the front (the 77-79 springs will fit your stock coil buckets) and the leaves for your stock rear springs.
Old May 2, 2007 | 03:57 PM
nighthawk285
and would I just go with the 6" and 6", or a 6 in the front and 4 in the back?
Old May 2, 2007 | 05:41 PM
fishmanndotcom's Avatar
fishmanndotcom
i would (actually did) buy the 5.5" coild from BC bronco, and then a pair of 6" rear springs from BC bronco and you'd be good to go!
-cutts-
Old May 3, 2007 | 05:49 AM
kjett's Avatar
kjett
-cutts-
Yep, that'll do it!!
Old May 3, 2007 | 01:02 PM
nighthawk285
all right, thanks guys
Country705
Kentucky Chapter
Sep 30, 2009 07:56 PM
9.ford.5
Jan 30, 2009 11:55 PM
nobodyspecial
Offroad & 4x4
15
May 31, 2008 04:42 PM
Bullride_101
Offroad & 4x4
Jun 16, 2007 11:04 AM
ech0sh4y
Jun 1, 2007 09:16 PM
