door ajar!
Old May 2, 2007 | 08:02 AM
doghausbass's Avatar
doghausbass
door ajar!
my door is ajar light comes on and off- I imagine i need to clean some connectors or something (I have slammed every door several times). Has anyone else had this problem- where do I look because I couldn't see anything?
Old May 2, 2007 | 08:06 AM
Dogwood36322's Avatar
Dogwood36322
Door switch is inside latch area. Spray WD-40 in latch area to clean . This should od the trick. Also do a search of threads for door latch and you will see previous posts.
Old May 2, 2007 | 09:11 AM
doghausbass
thanks- I'll get right on that
Old May 3, 2007 | 04:34 PM
aquatictherapy's Avatar
aquatictherapy
Dogwood, Thanks for the fix, I too had the problem. Scott
