tranny temps
Old May 1, 2007 | 09:48 PM
01 f-350 dually's Avatar
01 f-350 dually
tranny temps
What is the norm tranny temp running 73mph on the freeway on an 80 degree day.
Old May 1, 2007 | 09:52 PM
Uzumati's Avatar
Uzumati
Generally 60 - 100 degrees over ambient depending on how heavy you are towing/hauling.
Old May 1, 2007 | 09:55 PM
01 f-350 dually
empty? Im running 140
Old May 1, 2007 | 10:06 PM
Uzumati's Avatar
Uzumati
80 + 60 = 140 (On the lower end of normal), Thats a healthy tranny
Old May 1, 2007 | 10:08 PM
01 f-350 dually
its my 3rd in 50,000 miles
Old May 1, 2007 | 10:14 PM
Smokiesman's Avatar
Smokiesman
YIKES!!!!
Smokie
Old May 1, 2007 | 10:16 PM
01 f-350 dually
your telling me! not cheap!!!!
Old May 1, 2007 | 10:18 PM
Uzumati's Avatar
Uzumati
Where are you measuring the temp at? The 60 - 100 is from the test port on the driverside. What type of tranny are you using?
Old May 1, 2007 | 10:20 PM
01 f-350 dually
from the same place i think? the stud on the drivers side of the tranny, and it is the same one it came with, stock something or other
Old May 1, 2007 | 10:22 PM
Smokiesman's Avatar
Smokiesman
After reading posts such as these is when I installed a second cooler on my 99 PSD! Right now she has 148k on her and "knock on wood" she will hold up! I pull a 28 ft fiver and so far my temps even in Fl have been low! Have not seen close to 200 deg!!
Smokie
Old May 1, 2007 | 10:27 PM
Uzumati's Avatar
Uzumati
Who is doing the rebuilding or are you just getting ford reman's
Old May 1, 2007 | 10:29 PM
01 f-350 dually
a tranny shop has done all the rebuilding. Sounds like that could be a bad thing?
Old May 1, 2007 | 10:33 PM
Uzumati's Avatar
Uzumati
They may not be replacing some of the hard parts,
You are not to far from BTS and it will be the last tranny you have to buy.
www.brianstruckshop.com give him a call
Old May 1, 2007 | 10:36 PM
01 f-350 dually
i have heard of these. they are the ticket, from what ive heard
Old May 1, 2007 | 10:39 PM
Smokiesman's Avatar
Smokiesman
If you were really sick and went to the doctor and you weren't cured! You would get a second opinion right! You might want to help your truck and do the same!! After all he is your best friend right?
Smokie
