rear antilock light
Old May 1, 2007 | 06:57 PM
dyoungen's Avatar
dyoungen
Question rear antilock light
Recently the "rear antilock" light in the dash came on. What does this mean? The brakes work fine and it doesn't stay on, just comes on then goes off maybe not to come on for a few days. Brake fluid is fine. I just replaced the front disks a few thousand miles ago.
Old May 24, 2007 | 08:44 PM
amish77's Avatar
amish77
have you bled the rears any? Check the sensors and see if there is anything in the way of them, and of course the connections. Might be a loose one in there. I'd say the brakes are fine and the instruments aren't.
Old May 25, 2007 | 11:16 AM
dyoungen's Avatar
dyoungen
Right now I'm going to pull the drums to see if the breaks are ok. I haven't looked at them since I bought the truck last fall.
Old May 25, 2007 | 01:15 PM
Lazy K's Avatar
Lazy K
Check that the electrical connector at the master cylinder is clean and tight. I wouldn`t worry too much unless the light stays on.
