Sponsored by: Real Truck
What Gears?
Old May 1, 2007 | 05:26 PM
fordextreme's Avatar
fordextreme
Talking What Gears?
This may be a dumb question, How can i find out what gears I have in my truck? Ive looked on the diff and nothing there. I have a 2005 CC SB 6.0.
Just one of those things I dont know about this truck that I should know.
Thank You,
Sean
Old May 1, 2007 | 05:29 PM
Ace!'s Avatar
Ace!
Wasn't 3.73 the only gears offered on the single rear wheel trucks that year?
Old May 1, 2007 | 05:32 PM
fordextreme
I heard something about that awhile ago, however I wasnt sure if that was the same with the PSD.
Old May 1, 2007 | 05:38 PM
Beerstalker's Avatar
Beerstalker
I'm not sure if Ford ever offered anything other than 3.73 behind the 6.0L unless it had duals then you could get the 4.10. So if you don't have dual rear wheels then you have a 3.73 ratio. Limited slip or not I can't tell you, but I think if you check the tech folder at the top of the forum it can tell you what axle code is what and you just look at your door jamb sticker.
Old May 1, 2007 | 05:44 PM
fordextreme
Exactly what i needed to know. Thank You
Old May 1, 2007 | 05:58 PM
Ace!'s Avatar
Ace!
Actually I meant on the PSDs. The gas engines had other gears available.
