32 ford pu vin#
Old May 1, 2007 | 04:59 PM
splicrtek66's Avatar
splicrtek66
32 ford pu vin#
where is the vin # on 32 ford pu and what would i be looking for
Old May 1, 2007 | 05:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
No Vehicle Identification Number (VIN). Cars and trucks were registered by the serial (engine) number in those days.
The serial number is found on left side of engine above water intake.
Model B 4 cylinder serial numbers begin with: B-5,000,000
Model 18 (V8) serial numbers begine with: 18-1 and up.
If the current engine serial number doesn't match what is listed on the registration, the original engine has been changed. It's very common to see mismatched numbers on Ford cars/trucks of this vintage.
Old May 1, 2007 | 05:36 PM
splicrtek66
thank you Iwill take a look Jeff
Old May 1, 2007 | 07:23 PM
mtflat's Avatar
mtflat
If it's a V8, check for the 18-xxxxxx on the transmission half-bell. It wasn't on the block (early 32's might be different) Ford marked the tranny rather than the block, figuring the engine would be swapped out before the trans.
Probably find the vin on the top of the frame rail inside the engine compartment and under the cab.
Old May 1, 2007 | 07:50 PM
splicrtek66
thanks Jeff
Old May 11, 2007 | 02:11 PM
CapnJohn's Avatar
CapnJohn
Besides on top of the transmission half bell on the left frame rail around the steering gear column it should also be listed.
By the way go to www.fordbarn.com and the leads there should take you to some photos on this topic.
Old May 26, 2007 | 07:13 AM
ncranchero's Avatar
ncranchero
FWIW, the VIN on a '36 is on top of the left frame rail just in front of the cab.
redf100pu
Jul 10, 2023 08:06 PM
HAMS64
Aug 15, 2019 12:12 PM
tommyjq
New Member Introductions
Jun 27, 2015 01:31 PM
jailbar
1947 and Older Ford Trucks
Dec 31, 2014 09:54 AM
dbgphx
Aug 15, 2013 04:40 AM
