Steering Rebuild Question
Old May 1, 2007 | 10:21 AM
TexasGuy001's Avatar
TexasGuy001
Smile Steering Rebuild Question
The steering system on my F150 is completely stock. I know for sure the outer tie rod end on the driver side is sloppy. I am about to replace tie rod ends and ball joints etc. What all should I replace while doing this? I really only want to do this once and get an alignment once. That way I am done with that part of my truck. Can some one give me a quick run down or list of what all I should get at the parts store? Also, any tips to help make this project go smoother would be great!
Old May 1, 2007 | 01:00 PM
Lazy K's Avatar
Lazy K
You seem to have everything about covered. A ball joint seperator makes life a lot easier when splitting both trackrod ends and ball joints. A simple pickle-fork type is sufficient. Go for it and good luck.
