6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Break in?
Old Apr 30, 2007 | 05:05 PM
Buckarcher's Avatar
Buckarcher
Break in?
I ordered an '08 KR 6.4 a week and a half ago, this will be my first diesel. Build date is May 20. What do I need to know about break-in period for this truck? I am guessing go ahead and put load on the motor without sustained periods of high RPMs and staying away from the redline for the first few hundred miles.
Please no "drive it like you stole it" responses, only well reasoned strategies please. Thank you.
Old Apr 30, 2007 | 05:31 PM
Percys Armory's Avatar
Percys Armory
drive it like a rental
Old Apr 30, 2007 | 05:41 PM
Buckarcher's Avatar
Buckarcher
NEXT!
Old Apr 30, 2007 | 05:44 PM
Percys Armory
how do you normally break in your vehicles?
Old Apr 30, 2007 | 05:58 PM
66stang351's Avatar
66stang351
Ford's literature states no heavy loads and vary engine RPMs regularly for the first 1000 miles.
Old Apr 30, 2007 | 06:49 PM
Buckarcher's Avatar
Buckarcher
That's pretty much what I did with my motorcycle. Load by acceleration, smooth and steady with no sustained periods above 2500 RPM's for the first 500 miles. My current truck had 500 miles on it when I bought it.
I didn't know if diesels folowed the same guidelines. BTW, what is redline on that truck, the tach in the truck on the lot went to around 5000 with no indication of a safe zone. I am under the impression diesels are quite a bit lower.
Old Apr 30, 2007 | 10:28 PM
tn mac's Avatar
tn mac
the powerstrokes are high reving engines.
Old Apr 30, 2007 | 10:38 PM
rollerstud98's Avatar
rollerstud98
mine maxes out at maybe 3400 rpm
Old Apr 30, 2007 | 11:35 PM
blackhat620's Avatar
blackhat620
Here is the link to the procedure in the 6.0 Tech folder should be the same for the 6.4L. See posts 5 & 6
http://www.ford-trucks.com/forums/23...ight=breaking+
Hope this helps
Old May 1, 2007 | 12:11 AM
Big Sky Rancher's Avatar
Big Sky Rancher
www.ford-trucks.com/forums/239418-breaking-in-the-6-0l.html?highlight=breaking+
Hope this helps
Great info there. Thanks for the link, blackhat.
Old May 1, 2007 | 02:05 PM
Buckarcher's Avatar
Buckarcher
That's what I needed, thank you.
