as soon as it warms up it dies
I gotta 88 ford f150 its gotta 302. It starts up fine and will run great until it warms up then it just dies and wont start again til it cools down. When it shuts off its got 35 pounds of fuel pressure so i dont think its the fuel pump. i put a new ignition module, throttle position sensor and a fuel filter on it and it still does it. Im out of ideas and i need some help.
hello 1988greenpig have you tried disconnecting the egr valve and pluging off the vacume line, this is where i would start because if it dies like you turned the key off,
this is a sympton of the egr valve,i dont know exactly but when an engine warms up the egr silinoid suposed to do something , and this ideal does not cost anything to try,
only a fiew minutes of your time , and however long it takes for your truck to warm up.
i hope this is it and good luck
Originally Posted by 1988GREENPIG
no i dont know how to do it or anyone who can do it and the closest auto parts store is 12 miles away
http://fordfuelinjection.com/?p=13
