Trailer question
Old May 4, 2007 | 09:13 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
From what I understand - maybe wrong?? Is that for each thread is calculated as one post. So if you post 30 times in this thread you get credit for one posting.
Old May 7, 2007 | 09:44 AM
d-hol's Avatar
d-hol
Well thanks for all the responses, I have had so much advice. I did by a trailer over the weekend. Its a Puma and its dry weight is 6800. Hope its not to much?
Old May 7, 2007 | 11:25 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
By the time you have all your personal stuff in it, I believe you will be over 7800 lbs. You probably won't have any probs pulling it, just be darned careful trying to stop it!!
You will be buying new front pads a little more often....That weight would be better served by a F250.
Old May 7, 2007 | 11:54 AM
d-hol's Avatar
d-hol
Wonder how they advertise the new F-150 pick up able to tow 11,000 lbs is that false advertisement? I see the comercial all the time
Old May 7, 2007 | 12:50 PM
MarkMoore's Avatar
MarkMoore
It's a base model, 4x2, regular cab truck, with 5.4l and 4.10 gears.
Old May 7, 2007 | 12:58 PM
blackhat620's Avatar
blackhat620
Actually it is 10,500lbs, and that is with the 5.4L HD tow package, 2WD, standard cab, long bed only. GCWR 15,800Lbs. So after you weigh this truck (at your local CAT scale) with you in it and your standard gear you may or may not have 10,500lbs of capacity left. Also bear in mind that factory added options will increase the truck curb weight and decrease the towing capacity (ie a stripped down XL will weigh less than a fully loaded Lariat), also larger 18" or 20" wheels will lower the tow capacity.
"Make sure vehicle payload (reduced by option weight) will accommodate trailer tongue load weight and weight of passengers and cargo added to towing vehicle. Addition of trailer tongue/pin load weight and weight of passengers and cargo cannot cause vehicle weights to exceed rear GAWR or GVWR. These ratings can be found on the vehicle Safety Compliance Certification Label."
http://www.fleet.ford.com/showroom/r...crp16Aug06.pdf
This is not false advertising, just marketing. Your results in the field may vary. All auto manufactures always show the "best case" scenario. And then to make matters worse the RV industry ups it some more when they tell you what RV trailer you can buy and pull with your 4.2L F150
http://www.fleet.ford.com/showroom/r...07_default.asp
Hope this helps
Old May 7, 2007 | 01:44 PM
d-hol's Avatar
d-hol
Yah thanks it does help. I tried looking all that stuff up in my owners manual. I could not even find my wheelbase in there. I looked it up on my sticker and it says wheel base is 139 inches there is not a 139 inch wheel base on the chart. I have the 4wd, FX4, 4 door F-150 w/18 inch tires. I just bought a 2008 Puma trailer with a dry weight of 6800 hope its ok.
Old May 7, 2007 | 02:26 PM
blackhat620
That is because you have a SB Screw with a wheel base of 138.5" and there is not enough room on the sticker for two extra places so they round up to 139" wheelbase.
Depending on your engine and gears, you have GCVWR of 11,000 - 15,000Lbs so max available towing capacity is 5,100 - 9,200lbs. This is from the chart in the links i posted above. If you have the Harley Edition you have the lowest payload capacity.
You really need to weigh your truck and Trailer at a CAT scale. BTW the 6800 dry weight of your Puma is before you add water (at 8lbs per gallon), propane, food, blankets, pots & pans etc. You will be suprised how much your Puma weighs when you have it loaded. Weigh your rig so that you don't overload it and also pay attention to your GAWR they are on your sticker as well.
Good luck
Old May 7, 2007 | 02:33 PM
d-hol's Avatar
d-hol
Well that explains that (wheelbase) but how and the F is the average Joe suppost to know that? haha confusing and frustraing to say the least. What is the basic opinon of those chips that increase HP?
Old May 7, 2007 | 02:58 PM
Steina's Avatar
Steina
CO River Rat
Before you "chip" that '07, you may want to have a chat with your service manager to get his feelings on the subject; any engine/tranny problems could be blamed on the chip and cost you $$$ because you "modded" your 150 in violation of the warranty.
Steve
Old May 7, 2007 | 03:13 PM
d-hol's Avatar
d-hol
yah thats what I have heard, I just wondered if anyone had any sucess or how they worked?
Old May 7, 2007 | 03:31 PM
Steina's Avatar
Steina
CO River Rat
A friend of my son's chipped his '04 F250 PS for towing and it runs very strong; he just needs to control his right foot when he isn't towing!
Steve
Old May 7, 2007 | 05:42 PM
  #28
BPofMD's Avatar
BPofMD
Veteran: Navy
Again!!! Listen...it isn't how much you can pull! Or how fast you can go with it, it's how much can you SAFELY pull and STOP that beast!! If you upgrade your "pulling power", upgrade your STOPPING POWER too!
Old May 7, 2007 | 07:21 PM
  #29
bigredtruckmi
Veteran: Navy
It used to be (don't know for sure now) but the dry weight was no furnature bedding, etc in the trailer. I know ours went up about 1500lbs when we took it to a scales.
Old May 7, 2007 | 07:23 PM
  #30
smokestone52's Avatar
smokestone52
Stopping is something not to be taken lightly.
My rig and set up is totaly different than yours, but I have to darn well think ahead before applying brakes. And I am under my tow rating by 2000 lbs.
I have a prodigy controller, and good brakes all around.
Just vision that rig pushing you through a red light. I seen the results of that about two years ago. A huge fiver pushed a F-350 through a busy intersection. Or I should say tried to do so, before his rig was demolished by a tractor trailer rig. No one died, but panties needed cleaning!
