Throttle cable?
Old Apr 29, 2007 | 09:50 PM
Jrock909's Avatar
Jrock909
Throttle cable?
Guys are the 92-96 302EFI throttle cables the same length as the lightning cables? I need another throttle cable because my old one broke the hard plastic sleeve inside of the cable itself so it kinks up and won't work properly? Is this a part that Ford keeps in stock also?
Old Apr 30, 2007 | 01:39 AM
royallenz06's Avatar
royallenz06
if they are they same as an 88 with a 302 which i beleive they are then good luck with ford having one. mine broke about a month ago and the ford dealer said they were now obsolete parts. i found one off atruck in the junkyard. good luck.
Old Apr 30, 2007 | 02:39 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FTE members have direct access to a Ford Dealer, who's a sponsor here. Click on y2kfordparts or Discount Ford Parts. Tell them what part(s) you need, and give them the info that pertains to the parts you need. Year, engine, transmission, etc. You will be informed of parts availability and get a discount on the parts, also.
You will get: fast and friendly service from experienced Ford parts personnal.
You won't get: the runaround.
