fuel pump?
Old Apr 29, 2007 | 08:40 PM
notlowyet's Avatar
notlowyet
fuel pump?
where exactly is the fuel pump supposed to be on a 93 302 HO? Is there one that bolts to the block, in the tank, or on the frame? It was EFI but I'm in the process of swapping it to carb'ed.
Old Apr 30, 2007 | 04:41 AM
HemiEater's Avatar
HemiEater
should be in the tank I would think.........
Old May 1, 2007 | 08:43 PM
61F750's Avatar
61F750
It's probably on the frame rail (near the fire wall) below the steering column. Looks like a cannister on the fuel line with wires hooked to it.
Old May 2, 2007 | 08:58 AM
Conanski's Avatar
Conanski
302HO only came in cars.. and the fuel pump was in the tank. If converting to a carb you can change the timing cover to the older style and mount a mechanical fuel pump, or just mount an electric inline somewhere.... assuming whatever vehicle this is going into doesn't already have a pump you can use.
Old May 2, 2007 | 01:51 PM
notlowyet's Avatar
notlowyet
I didn't know there was a difference, yeah, its from a 93 t-bird, so now I just have to check and see if the Mazda B2200 has an intank pump as well
Michael Levy
15
Dec 17, 2014 05:12 PM
creedua
Jun 12, 2014 02:32 PM
jdonovan
May 15, 2011 06:52 PM
patman247
Apr 24, 2011 11:51 AM
