1978 - 1996 Big Bronco
85 bronco efi overfueling
Old Jun 21, 2001 | 06:06 AM
autotecn's Avatar
autotecn
i have a 85 bronco ECC IV engine management system when trying to start it wont have to diconnect the efi pump crank it to get rid of the excess fuel out of the engine and while cranking it have some one to re attach the fuel pump to get it going.
also it dies if i try to accelerate but okay at idle really require urgent attention on this problem pulled out fault codes which indicate 2 only ECT sensor which i replaced to no avail and EGR which has been disconnected help please
desperation
Old Jun 26, 2001 | 08:14 PM
RonBo's Avatar
RonBo
Try purchasing a new fuel pump relay. They're about $5 at any parts store, and take about 30 seconds to swap out.
If that isn't the problem, you need to define "overfueling". Are you running rich ? Check your fuel pressure regulator. Pull the vacuum line to it, and see if any fuel comes out. If it does, your diaphragm is wasted. New one is about $40, and is a slight pain in the ##### to replace, because of the three Allen head bolts holding it on. The one nearest the firewall is tough to reach if you have even slightly enlarged hands.
Old Jul 1, 2001 | 04:06 PM
Bob_VT's Avatar
Bob_VT
Okay I just fixed this type of problem last week on another brand vehicle. What it turned out to be was a clogged Cat Converter. It was killing the engine from the other end causing what appeared to be an "over fueling" problem. This was on a 1989 truck. My Cat Conv clogged in my 84 also. You might want to just have someone rev the engine once it is running while someone just feels the amount of exhaust from the tailpipe. Or take the other approach and disconnect the Cat and start the truck.
Old Jul 1, 2001 | 09:30 PM
bigfordman70's Avatar
bigfordman70
Eightyfive Flareside
Oct 26, 2011 06:47 PM
dustermaniac
Oct 2, 2005 05:57 PM
jwtimme
Apr 30, 2004 07:26 AM
moritz1024
Apr 11, 2004 06:40 PM
GREG DOZIER
Feb 22, 2003 10:04 PM
