cruise problem
Old Apr 29, 2007 | 12:12 AM
muddbugg's Avatar
muddbugg
cruise problem
I have a 94 f-150 the cruise,horn and airbag quit working all at once can anyone tell me what the problem might be i sure miss my cruise.
Old Apr 29, 2007 | 07:17 AM
92F150Flare's Avatar
92F150Flare
Welcome again......I'm not sure at all.....might be a fuse that controls them. Take a look at your fuse panel and see if there is one common to all those.
You might want to cruise on over to the parts house and pick up a manual too...not to pricey.......lots of great info in them.
Good Luck
Old Apr 29, 2007 | 10:03 AM
quicklook2's Avatar
quicklook2
the clock spring behind the wheel is broken.
about $100 to get the part.
many hits if you search "clockspring".
Old May 1, 2007 | 10:46 AM
rattosh51's Avatar
rattosh51
Just had mine to the dealer for a quote:
airbag sliding contact (clockspring)-$174
labor to install--$144
Told him to forget it.....got the procedure from service manual.
Old May 1, 2007 | 12:21 PM
95Ford4x4's Avatar
95Ford4x4
local dealership here quoted me at $104, but i had a spare one to put on my truck.
Old May 1, 2007 | 12:24 PM
95Ford4x4's Avatar
95Ford4x4
it only takes about 10 minutes to get the steering wheel off if you got a puller and some mech. sense. my 95 required a puller with 2 claws not the type with the screw in bolts(didn't find that out til i had bought a puller and went home to take off steering wheel. luckily i had a claw type puller i was able to use to get it off. it's not hard and i wouldn't pay anyone $144 to do something so easy.
Old May 1, 2007 | 01:05 PM
rattosh51's Avatar
rattosh51
Thumbs down
"i wouldn't pay anyone $144 to do something so easy"
Exactly my thoughts...that's why I told him to forget it...nice ripoff.
Old May 1, 2007 | 01:09 PM
95Ford4x4's Avatar
95Ford4x4
my only concern when i took mine apart was the airbag, i'd never removed the steering wheel with an airbag before and wasn't quite sure what to expect, but it was easier than removing the horn button on some older fords.
Old May 1, 2007 | 03:21 PM
quicklook2's Avatar
quicklook2
just remember to disconnect the battery.
and watch for static electricity.
when out of vehicle hold airbag away from you.
Old May 3, 2007 | 10:51 AM
rattosh51's Avatar
rattosh51
The Y2KFord website has these for $94.57....quite a bit better than the dealer.
I'll definitely do this myself now.
