do all 302 do this
Old Apr 28, 2007 | 11:47 PM
90ford4x4's Avatar
90ford4x4
do all 302 do this
when i start it, it seems like tyhe fan is real loud lots of wind noise, is there a cure for this
Old Apr 29, 2007 | 06:02 AM
alz's Avatar
alz
I'm pretty sure that's normal. Mine does it for a few seconds and then quiets down. I believe it's your clutch fan.
Old Apr 29, 2007 | 09:17 AM
Fully_Loaded's Avatar
Fully_Loaded
Yes it is your fan clutch. If it is going bad I have to reccomend that you replace it with a factory one from the dealer. I never have had any luck with the cheapo ones.
Old Apr 29, 2007 | 01:21 PM
90ford4x4's Avatar
90ford4x4
does the fan run all the time or is there a t stat sensor
Old Apr 29, 2007 | 03:39 PM
pfogle's Avatar
pfogle
The fan has a thermal clutch on it, it runs when cold for a brief second while the fluid gets in where it goes. It locks up when the clutch (through under hood temps, or the shaft on the water pump) reaches a certain temp (180 to 210 degrees Fahrenheit). If it makes noise all the time replace it, if it quiet down after 10 seconds or so it's normal.
