smoke question
Old Apr 28, 2007 | 10:34 PM
jays power stroke's Avatar
jays power stroke
smoke question
Hello every one wanted to say what a great site this is.I have a 2000 7.3 psd 6 speed with a aem intake, aih delete,waste gate mod,ccv mod, & 5 inch exhaust.My question is this latley ive noticed smoke coming out of the hose for the ccv mod at idle is when i notice ut the most and its a prety good amount?I have also noticed the egts are about 200 degrees higher.dont know if its something major or what? i would appreciate any information thank you
Old Apr 28, 2007 | 11:04 PM
kennedyford's Avatar
kennedyford
NORMAL smoke from ccv mod if not piped to exhaust or rear of truck....200 degrees bad, possible stuck ebpv?
Old Apr 28, 2007 | 11:06 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Jay, it is normal for a misty-smoke looking stuff coming out of the hose. As long as it is a constant plume of smoke, and not a puff-puff-puff stream, then you are fine. Puffing means you have cylinder(s) with rings not sealing correctly, letting compression gasses past the rings into the crankcase.
Old Apr 29, 2007 | 07:09 AM
Uzumati's Avatar
Uzumati
The CCV vent sounds about right like Kris said. The 200* increase in EGT doesn't and can usually be traced to 2 things Intake restriction/boost leaks and like Troy said exhaust restriction.
Old Apr 29, 2007 | 08:33 AM
jays power stroke
thanks for the info.it had me concerned cause i just started to notice it.I didnt notice it happening before.it just seemd like alot of smoke. i will look into the jump in egt temp thanks again
Old Apr 29, 2007 | 08:44 AM
jays power stroke
how can u tell if the ebpv is stuck and how can i check for boost leaks
