1978 - 1996 Big Bronco
Ac Blower Motor Too Weak
Old Apr 28, 2007 | 02:41 PM
robjs111's Avatar
robjs111
Can Anybody Tell Me If The Actual Blower Motor Or Fan Can Be Upgraded To A Larger Or Faster One? Ac Blows Cold In My 78 Bronco But Seems Like Air Is Not Coming Out With Enough Power?? Heard That U Can Upgrade But Not Sure. Thanks.
Old Apr 28, 2007 | 05:01 PM
chevygoneford's Avatar
chevygoneford
are you sure that the door that switchs from vent to floor is working mine had a vacuum leak fixed it and everything back to normal good straem of air
Old Apr 28, 2007 | 07:23 PM
robjs111's Avatar
robjs111
had can i tell if it has a vacuum leak? have a 78 bronco. thanks.
Old Apr 28, 2007 | 09:43 PM
chevygoneford
turn selecter on vent then turn blower on high check the flow of air from vent and then see if you can feel air coming out of the floor vents and defroster usually if air is coming out of all three your vacuum is weak and the door that switchs the vent flow around isnt closing all the way. that means you have a vacuum leak out there on the modulater or the modulater is bad on the housing where your heater hoses go in good luck
Old May 1, 2007 | 10:50 AM
kameronth's Avatar
kameronth
I looked around for a faster blowing fan on my 88 and had no luck. I did have a vacuum problem as well and that did not help it out. I could feel air coming out of my defrost and floor exits. It wound up being the canister. Just do as chevygoneford said and check for leaks.
Matt1966
Nov 11, 2015 08:13 PM
Mikey_23_ny1
May 29, 2015 11:19 AM
gergster66
May 20, 2012 12:31 AM
Marky48170
Sep 14, 2011 11:10 PM
krane operator
Jun 30, 2005 10:19 PM
