No. Shocks don't have anything to do with the alignment of the wheels.
Alignments are good, don't get me wrong. You have them done regularly but don't do it just because you put shocks on.
The function of the shock is to absorb the energy stored in the spring and convert it to heat. They support no weight or help to locate any part of the running gear.
[QUOTE=Monsta]No. Shocks don't have anything to do with the alignment of the wheels.
QUOTE]
I would only do alignment if:
it is pulling to one side (not a tire or brakes)
an uneven tire wear
replaced tierod ends, joints or bushings.
I have found that to adjust the caster / camber the top ball joint must be loosened up and an adjustable shim used to make the adjustment. If you don't have the adjustable shim all you get is a toe in setting. Easy to see the shim, just turn the wheel to each extreme and look under top ball joint nut. If you don't see a star washer assembly it is factory shim and never been adjusted.
So unless you have 1,2,3 above don't waste the $$. Jim
