Why do bigger tires get worse gas mileage? nt
Larger tires - MPG Calculations
ANOTHER FACTOR
A larger diameter tire also has a larger circumference and travels farther wth each revolution. Your odometer is calibrated for a specific dia/circumference tire. The larger tire will throw your MPG computations off a little making it appear that you have traveled a shorter distance (based on the odometer reading /fewer revolutions) on a tank of gas.
Going from a 31 inch dia. tire to a 33 inch dia tire effects the actual distance rolled by approximately 6 % as an example.
Example: So if you are using 33 inch tires and the odometer is calibrated for smaller 31 inch tires and the odometer reads 300 miles you have actually traveled 318 miles. Say you used 30 gal of gas to make this hypothetical trip. The MPG calculation will be 10 MPG, it is actually 10.6 MPG
on
In other words regular old fashioned air we breathe...
I'm not too optimistic on 100% Nitrogen filled or nitrogen enriched anything... Tires or Gasoline
Larger tires also lift the truck, allowing more air turbulence under the truck, increasing drag and reducing efficiency.
Generally, larger tires are heavier which as unsprung weight adversly affects handling as well as acceleration [slower] and braking [longer].
If you want to play [increased traction, looks, etc.], you have to pay!
Turn the wheel exactly 1 revolution & count the turns of the driveshaft.
Divide the driveshaft revolutions by 2, & that is your ratio.
For instance -
If 1x wheel revolution gives you 7x driveshaft revolutions - you have a 3.55 (or 3.54) axle ratio.
Or 8.25 revolutions would mean a 4.11 axle, & so on.
