Dead Battery - Battery Swap?
Originally Posted by Randy777
When you replace the batteries does the computer have to relearn everthing again or is there a way to keep one hooked up while they are being replaced. Randy
Yes the computer has to relearn anytime the batteries are disconnected.
Hope this helps
Randy
Randy
The other option is to get a memory saver and plug it into the lighter while you swap the batteries.
Originally Posted by jbullfrog
You can change them 1 at a time in the parking lot of the store, or at your shop and then return the dead batteries for the core deposit. Simply remove the negative cable first and then the positive cable. I stick the positive in a beer Koozie once it is removed while I swap the battery to keep it from touching anything.
Proper procedure for un-hooking dual batteries is:
1) Disconnect Ground cable at Secondary Battery (LH)
2) Disconnect Ground cable at Primary Battery (RH)
3 Disconnect Positive cable at Primary Battery (RH)
4) Disconnect Positive cable at Secondary Battery (LH)
Reverse this procedure for hook up.
Firefighter 1406
56
01-05-2017 07:21 PM
whimsy
29
09-28-2016 05:44 PM
Fishin76
1999 to 2016 Super Duty
01-12-2011 07:48 PM
