transmission problems
Old Apr 27, 2007 | 08:24 PM
blkfx405's Avatar
blkfx405
On my way home from work the truck was reving between 3 & 4TH gear then sometimes 2nd and 3rd.Then it would't take off in 1st.Got home ok but a bitt concearned so I decided to check the fluid level,it was fine.Started the truck put it in gear nothing.Would not pull in reverce or drive.This happened all of a sudden.Another crazy thing for a few min.when I put it in reverce I had no peddle, change to D I had trottle put it in N and had throttle.I cycled the key the problem went away,but still would not pull till you got up to about 2 thou. rpm's then slipped real bad but would move.I put the truck back to stock,but it did not help.I need some advice,the truck only has 61,000 miles on her this dosen't seem right.
Old Apr 28, 2007 | 12:23 AM
mhoefer's Avatar
mhoefer
try setting back to stock and re learn strategy (batter disconnect with lights on) see if you problems go away? It will take a while to relearn, perhaps then re load the Xcal and see if its better...
Old Apr 28, 2007 | 07:11 PM
blkfx405's Avatar
blkfx405
I unhooked the battery's like you said the truck did alot better except when shifting from 3rd to 4th.It slips between gears.
