Sponsored by: Real Truck
trailer brake install ?
Old Apr 27, 2007 | 05:06 PM
bigbadwolfe's Avatar
bigbadwolfe
Unhappy trailer brake install ?
hi guys i am putting in a trailer brake setup on a friends 2000 250 and i need to know where the plug is under the dash and what color wire runs to the back to the plug for the trailer brakes thanks
Old Apr 27, 2007 | 07:41 PM
country2's Avatar
country2
Does it have the tow package already and you are just installing the controller or are you installing the whole 9 yards?
Old Apr 27, 2007 | 09:04 PM
bigbadwolfe
it has the tow package
Old Apr 27, 2007 | 09:05 PM
bigbadwolfe
just the controller
Old Apr 27, 2007 | 09:16 PM
country2's Avatar
country2
The controller I installed had instructions and all I did was mount it below and to the right of the steering wheel. The plug is in that general vacinity. I had to get a relay and harness that was in the glove box (came with the tow package) and install it under the hood on the left hand side. That is all I did all wiring and the 7 pin connecter should be wired.hope this helps.
https://www.ford-trucks.com/forums/5...ake+controller
Also do a search on this forum for brake controller that may help
Old Apr 28, 2007 | 11:23 PM
bigbadwolfe
so no one knows the wire colors
Old Apr 29, 2007 | 02:47 AM
Cowboy Brett's Avatar
Cowboy Brett
The wire colors on the harness? I'm pretty sure this is the one you'll have...
Dark Blue - Brake Control Output
Brown - Dimmer Control (Probably not used on your controller)
Lt. Green - Brake Switch Signal
White - Ground
Red - 12V Power Supply to Controller
Old Apr 29, 2007 | 08:48 AM
edjunior's Avatar
edjunior
I don't know the wire colors either, but the Ford adapter you get for your controller should only plug in to the plug in the truck. It is under the dash on to the right of the steering column, almost to the center console wall. That's all I needed in my 2003 was the Ford adapter. Just plugged it in and hooked it up to my controller. Piece of cake!
bird-n-buck
Nov 27, 2012 09:57 PM
MDSuperDuty
Apr 27, 2011 06:23 PM
jwpfled
2004 - 2008 F150
Dec 19, 2006 07:37 AM
gunshop
All Things Towing
Oct 6, 2003 09:24 PM
