93 f-250 column
Old Apr 27, 2007 | 04:47 PM
dyrtbyrd's Avatar
dyrtbyrd
93 f-250 column
I have a 93 f-250 manual tranny, cruise control, tilt steering wheel column and am womdering if a 96 column would fit it? Thats $200 -junkyard.
The column broke something inside and needs to be replaced. the dealership wants $400+ to fix it but said a kit is sold for the bearings inside the column and thats only $65 any advice on which way to go? I am pretty good with repairs but getting into the column and replacing those parts sounds like it might be hard?
Old Apr 27, 2007 | 04:56 PM
dwaymar's Avatar
dwaymar
its a bugger but with Little help from this group and you'll be back on the road in no time
Old Apr 27, 2007 | 07:25 PM
Mr. Bob's Avatar
Mr. Bob
They are not that bad at all to get apart... pull it out of the truck and rplace the broken bearings... yopu never know what you are going to get with used components...
Does the 1993 have an air bag?? because the 1996 will...
Old Apr 27, 2007 | 10:03 PM
Totally Tuna's Avatar
Totally Tuna
I have the same problem on a '92. I found a local mechanic that is going to do the repair for 150 plus parts. I think the bearing is about 35.
Old Apr 28, 2007 | 01:12 AM
PLC7.3's Avatar
PLC7.3
What exactly is the problem as there are several items that can break......
Old Apr 28, 2007 | 10:02 AM
dyrtbyrd's Avatar
dyrtbyrd
my 93 has no air bag and the problem is the steering wheel is very loose sort of a tilt feature within the tilt it moves up and down..
Old Apr 29, 2007 | 06:56 AM
dyrtbyrd's Avatar
dyrtbyrd
Are there any special tools that are needed or that can be rented that would make this job a little more easier?
