1978 - 1996 Big Bronco
Unique Tailgate/Window Problem
Old Jul 31, 2001 | 07:44 AM
Bob_VT's Avatar
Bob_VT
Okay, this one is new to me. Recently on my 78 Bronco the tailgate glass seemed like it fall out of alignment. Yes I checked all the bolts they are fine. The glass will not go completely into the gasket at the top and falls short by a 1/2 inch. Is there a limiting switch? I could not find one. I checked the alignment on my fiberglass top too. I am just stumped?
78 Bronco w/ 3/4 ton springs, plow and 89,000 original miles
84 Bronco (my current body work repaint project)
93 SHO got to have the speed and handling to play with
Bob
Old Jul 31, 2001 | 12:46 PM
83bigbroncoguy's Avatar
83bigbroncoguy
My 83 does the same thing- it's one of the nylon gears in the motor (on mine it's the one that moves the regulator, I think).
Old Jul 31, 2001 | 01:33 PM
D_STICK's Avatar
D_STICK
This sounds like exactly what both my passenger power windows did right before they went out. Within a few days they were completely gone.
I picked up a gear replacement kit at the dealer. Easy to install. I assume they have the same type of kit for the tailgate motor. None of the autoparts stores (Autozone, Chief, Checker) here in Vegas had replacement kits. Dealer only is what I was told.
Good Luck!
Stick
'89 Bronco XLT, 5.8 EFI
Old Jul 31, 2001 | 03:27 PM
rywegh's Avatar
rywegh
I got my replacement gears at the junk yard. It might help that the junk yard I went to just deals in FORD.
Old Jul 31, 2001 | 06:28 PM
rwjr's Avatar
rwjr
you can check the nylon gears in the motor it's a moderate job to do (takes some hand-wormin to get it in), but just roll the window up with the tailgate down, remove the access panel on the inside of the gate, then take out the 3 bolts (or nuts) for the motor...if the gears are bad, they are 25 bucks new at advance.
Old Jul 31, 2001 | 10:02 PM
Flash's Avatar
Flash
