1978 - 1996 Big Bronco
Trouble getting new brake lines
Old Apr 27, 2007 | 10:45 AM
ferreed's Avatar
ferreed
I've got an 86 Bronco that I'm having trouble getting the rear steel brake lines for. Specifically, mine has 3/8" fittings at the wheel cylinders and 7/16" fittings at the 3-way distribution junction on the axle. I didn't believe it at first, but after trying a 3/8" fitting on that junction it is clearly a 7/16" fitting. So, is this the case with all older Broncos and where do you guys go to get 3/8" to 7/16" lines or adapters? I've been told locally that you either can't get the parts I need or you have to have a shop make them for you.
Any help will be greatly appreciated.
Old Apr 27, 2007 | 08:55 PM
82MustangGT's Avatar
82MustangGT
try these guys i have goten many lines from them http://www.classictube.com/
