adjustable rockers
Old Apr 27, 2007 | 08:52 AM
TG28's Avatar
TG28
adjustable rockers
i installed crane adjustable ductile iron rockers on my recent 390 rebuild, engine runs good but after it reaches operating temp. i get a little lifter noise. i have run the valves twice now going 1 full turn after 0 lash, is this too much or not enough, since i still have noise i think maybe i should go another 1/2 turn but 1 1/2 turns seems a little much. any suggestions?
Old Apr 27, 2007 | 09:08 AM
73F100*8Mile's Avatar
73F100*8Mile
1/2 to 3/4's turn is what I was told and i went 1/2 on all mine w/ no issues. Are you sure you're starting at zero lash? Thats something you gotta play with to get used to feeling so you don't over/under tighten the setup. Were your rockers installed on original shafts? Did you mike the shafts and rockers to see what kinda tolerance you were gonna have when assembled?
Old Apr 27, 2007 | 12:37 PM
TG28's Avatar
TG28
my original shafts were worn really bad so i got brand new oem shafts. i did not check tolerance on the new shafts, wish i had.
73 fourxfour
38
Feb 20, 2011 02:55 PM
tater_51
Dec 31, 2010 06:45 AM
capridude
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 23, 2008 12:37 AM
bigblue
May 22, 2003 08:31 PM
