Lobe Separation
Old Apr 27, 2007 | 06:36 AM
scottlane's Avatar
scottlane
Lobe Separation
I've noticed that most rebuilds for the 390 recommend the Crane 343901/343941 (and similar). These seem to have the 112 degree separation. I've noticed that the Crane 343904 and 343902 have similar specs Dur 260/ 272, Lift .501/ .533 but differ in the lobe separation. The 902 has 110 degrees of lobe separation while the 904 has 112. It's my understanding that the lower the separation degree the sooner low end power is developed. Is that correct? Would this 2 degree difference help or hurt in my 390 stock rebuild (except for the KB150 pistons and cam)? I'm looking for a daily driver with good performance and better mileage than I'm getting in my 360.
Old Apr 28, 2007 | 12:44 PM
Scouder's Avatar
Scouder
The wider LSA is going to give you better mileage, but that 2 degrees is probably not noticeable.
-Scouder
Old Apr 28, 2007 | 01:15 PM
rusty70f100's Avatar
rusty70f100
Nope, look again. They're the same cam.
Go to http://www.cranecams.com and type the cam numbers in the "Cam Timing Spec Card" box on the right. Compare the valve events. They're identical, and as such the cams are identical.
Old May 1, 2007 | 04:23 PM
1975Ford's Avatar
1975Ford
The Crane Cam with part numbers 343901, 343902 and 343904 are the same cam.
Old May 1, 2007 | 05:00 PM
scottlane's Avatar
scottlane
Y'all are right. I was looking at these specs on the Crane Cams somewhere else and they had the different lobe separations. Never would have asked the question otherwise.
On a side note, why do these cams carry different part numbers if they are identical cams?
Old May 1, 2007 | 05:18 PM
Redmanbob's Avatar
Redmanbob
he's got a good question there.. Not like I'm going to go look myself to see LOL
Old May 1, 2007 | 05:34 PM
rusty70f100
Marketing. One is in their "Truck Power" line, the other is in their "PowerMax" line.
Old May 1, 2007 | 10:46 PM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Its been my experience that the wider LSA..give's you a broader TQ band and well idle better than a closer one...It may not give you as much Peak TQ that a shorter LSA. by a few lbs...
My new roller is on a 112* LSA....with a .640/650" lift ...240/248* duration..I thought this cam maybe a little to much for my build..But after Talking too KC..He said no problem.. JMO..
RJ
