1978 - 1996 Big Bronco
Transfer Case
Old Jul 31, 2001 | 03:56 PM
Flash's Avatar
Flash
Transfer Case
Old Aug 4, 2001 | 01:07 PM
85bronco's Avatar
85bronco
Transfer Case
I have an 85 Bronco. Just within the last day or so, I have been noticingthat my tranfer case shift **** has been kicking to the side when I hit the gas. Any ideas?
Thanks
Old Aug 4, 2001 | 02:21 PM
alpo23's Avatar
alpo23
Transfer Case
Look at the driverside motor mount. it is breaking or broken. this is allowing the driveline to lift and roll to the passenger side as you accelerate. since your t-case handle is mounted to the adapter between the tranny and the t-case it is moving with them. If you had a 4-speed the shifter it would move the same as the t-case handle. I suspect you have a auto since you didn't mention it moving. Good luck
Eric
Proud owner of a '73 F-250 4x4 High Boy, 460 V8, NP435, NP205, Dana 60 rear w/Detroit Locker
And a '68 Bronco 289 v8 , NP435 , Dana 20
