tranny questions
Old 04-26-2007, 09:45 PM
joey40949's Avatar
joey40949
joey40949 is offline
Smile tranny questions
i have a 1994 f-150 4x4 with e40d trannie 5.8 engine well the trannie is going out cheapest ive found for rebuild was 1600 in my area and havent found used transmisson anywhere in my are im considering c6 swap will the trannie work with my transfer case or will i have to change it 2?
Old 04-27-2007, 12:08 AM
1994 F250: 351, C6's Avatar
1994 F250: 351, C6
1994 F250: 351, C6 is offline
I beleive the only transfer case offered in your vehicle was the BW 1356, the same transfer case found behind the C6 in my 1994 F250, so yes the two should work toghehter.
Aside from that, there are two things that you should know before attempting this swap:
1) Make sure you get a C6 from a 4x4, one from a 2 wheel drive vehicle will not work for your four wheel drive application.
2) The C6 is shorter than the E4OD and will require crossmember relocation and modifactions to your driveshafts. This will cost you a lot of money and be a hassle.
Sure, the C6 is an awesome transmission, but the E4OD is pretty tough, esspecially with some modifications. My dad is running a bone-stock E4OD behind a 460 in his 1997 F250 that is used for heavy towing and it is still performing well after 120,000 miles. Long story short, I beleive that the swap to a C6 will not be worth it unless you are extensively modifying the vehicle.
Old 04-27-2007, 12:32 AM
joey40949's Avatar
joey40949
well i kinda dont have the money for a rebuild at the moment and its my daily driver ive looked every where around for a used trannie and cant find one my dad is a diesel/automotive mechanic he can build driveshafts and modify stuff real good so thats not a prob if i could find a used trannie that was good then i wouldnt but being this is my daily driver i need it going
Old 04-27-2007, 06:27 AM
hgufrin's Avatar
hgufrin
hgufrin is offline
there is a place in Schaumburg Ill that has the E4OD for $900 with a $500 Core charge. 24month / 24K mile warranty. Check Ebay. I think they are called Road's Transmission.
Old 04-27-2007, 07:25 AM
alstieg's Avatar
alstieg
alstieg is offline
When I needed a tranny for my '95 I bought my 4r70w 4 sp auto at RoadMaster in schaumburg. It was completly rebuilt and is still running and shifting great after 2 years. They have very good prices. for me, driving there was cheaper than shipping. They ship anywhere, even china. One thing is though don't expect to much of your core deposit back. whatever is wrong with your core gets deducted out of your core charge. my core charge was 300-400. I got back $102. overall, Good Transmissions and reasonal prices.
Old 04-27-2007, 09:21 AM
hgufrin's Avatar
hgufrin
hgufrin is offline
what alstieg says about the core is definitely true.
Old 04-27-2007, 07:23 PM
alz's Avatar
alz
alz is offline
Another thing to think about, the E4od is an electronic trans and your computer will be looking for it. The c6 is also only a three speed, no overdrive.
Old 04-27-2007, 10:11 PM
tgil's Avatar
tgil
tgil is offline
i just had my tranny rebuilt and it was 1500.00 and it had alot replaced in it!
