'93 Inline Six- eating oil
Old Apr 26, 2007 | 01:18 PM
adipose's Avatar
adipose
My 1993 F150 inline 6 is eating about 2.5 quarts of oil per oil change. Oil change is always around 2500 miles.
Engine is not dripping a drop of oil on the driveway whatsover.
Last Fall I had a big oil leak repaired with manifold gasket replacement at certified local shop.
A mechanic contact stated to me that a Quart of oil is used up per 1000 miles, is normal on Fords.
Wondering if mine is eating more than normal. I believe it is.
Any I-6 owners out there experiencing this same challenge?
I tow my 1200lb boat about 3 to 4 times a month max - each trip roundtrip of about 60 miles is all up to boat ramp and back.
Fish On!
Adipose
Old Apr 26, 2007 | 01:43 PM
Skandocious's Avatar
Skandocious
It's pretty typical for these trucks to guzzle oil. I used to have to check on my 5.0L every time I filled up with gas to make sure I wasn't running dry on oil. My 5.0 burned about as much, if not more, than the amount of oil your burning. The cause of this? I have no clue.
Also got about 3k miles on my oil change in my 5.8L and I just had to put about a quart and a half in the other night... Just food for thought.
-Chris
Old Apr 26, 2007 | 03:34 PM
quicklook2's Avatar
quicklook2
my 130k 4.9 engine uses less than 1/16 of a quart in 3000 miles.
1 quart may be more common but not to me.
Old Apr 26, 2007 | 03:44 PM
maschronic's Avatar
maschronic
i have a 95 F250 4x4 5.8EFI. she is a little thirsty. she consumes about .5 quarts every oil change. i change it every 3k mile or so. not so bad.
Old Apr 26, 2007 | 03:54 PM
andym's Avatar
andym
I have owned several 300's and I don't believe that they should be using much oil at all. Anything more than a half a quart between changes is too much.
The '89 in my signature was using quite a bit of oil for a while, and it wasn't leaving any oil on the ground where it was parked. It turned out that the oil pan gasket was leaking badly, but only when the truck was being driven.
Old Apr 26, 2007 | 04:04 PM
adipose's Avatar
adipose
I wonder what is up!?
why is she eating so much oil ?
She pretty much runs like a champ?!
Old Apr 26, 2007 | 04:41 PM
Skandocious
Oh yeah I should also mention that my rear main seal leaks a bit on my 351... Not a lot but that might account for my oil consumption :\
Old Apr 26, 2007 | 07:55 PM
Phillip Guidry's Avatar
Phillip Guidry
Lifter cover gaskets is a common oil leak area with no "on the cement" type of warning. Does tend to keep the side of the motor wet though.
Old Apr 27, 2007 | 10:47 AM
adipose's Avatar
adipose
I had the lifter cover gasket replaced last Fall also!?
Old Apr 27, 2007 | 10:54 AM
quicklook2's Avatar
quicklook2
the oil is going somewhere.
do compression check.
wipe down entire engine and look for leaks.
park over a white surface and look for leaks.
Old Apr 27, 2007 | 06:24 PM
Big Blue 87's Avatar
Big Blue 87
Do you let the truck warm up? If not and you start it and fly (even more so with a boat) you will use up some. Also are you reving the snot out of it that can use up oil too.
