flasher speed slows down while idling
Old Apr 26, 2007 | 01:05 PM
jostrowski's Avatar
jostrowski
When idle at a stop light turn signal slows down but when I resume travel the signal speeds up. What causes this?
Old Apr 26, 2007 | 05:13 PM
Franklin2's Avatar
Franklin2
Get a voltmeter and check the voltage at the battery with the engine idling. It should be around 14 volts. If it's low, that would cause what you are talking about.
