1978 - 1996 Big Bronco
Exhaust tips
Old May 28, 2001 | 07:37 PM
fast freddie's Avatar
fast freddie
Exhaust tips
Old Aug 16, 2001 | 02:19 PM
tx83bronco's Avatar
tx83bronco
Exhaust tips
Does anyone know where i could find some nice 3" exhaust tips for some duals i'm planning to run on my Bronco. I've looked around and can only find 2 1/2" tips. I figured some deisel exhaust manufacturer would make them. If anyone could show me a link or something I'd appreciate it. Thanks
Old Aug 16, 2001 | 04:20 PM
galaxiefiveohoh's Avatar
galaxiefiveohoh
Exhaust tips
I've got a bunch of empty coffee cans around the house. Nuttin looks worse than those damn oversized tailpipes!
Old Aug 17, 2001 | 01:26 PM
tx83bronco's Avatar
tx83bronco
Exhaust tips
I hear you galaxiefiveohoh, i think i'm going to go with 2 1/2" exhaust because 3" duals wouldn't provide enough back pressure. Hey, restorit, cool site, thanks for the info.
Old Aug 18, 2001 | 11:04 PM
restorit's Avatar
restorit
Exhaust tips
No problem..... lots of good stuff (can't wait 'til I can afford some of it!). Good luck with your duals. A word to the wise.... don't run the tailpipes straight out the back, under the bumper, like you see on so many pickups. Run them out of the sides, before or after the rear wheels. If you have them arranged to point straight back, and you run with your rear window open, at all (even just cracked), the airflow passing around your truck will cause the exhaust fumes to roll straight back against the rear of your truck and in through the rear window. Running them out of the sides allows the airflow to "grab" the gases and suck them away from the truck. No use in going to all that work to end up with a nice truck that gives you a headache and makes you puke every time you drive it!
