02 SD 7.3 no start
Old Apr 25, 2007 | 04:57 PM
BillyPat's Avatar
BillyPat
02 SD 7.3 no start
When I turn on the key the dash lights and indicator lights flash on & off.
speedo needle & tach needle swing min to max.
when you try and start it just raddles.
Anyone have any suggestions?
Old Apr 25, 2007 | 05:09 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
your batteries?
did you check them?
Old Apr 25, 2007 | 05:57 PM
BillyPat's Avatar
BillyPat
No, I did not check the batteries.
Here is a little more info.
On Sun (4/22). I drove the truck and it started an ran fine. While driving home
I noticed that the tach & speedo were on '0', the "abs light was on, all other
gauges were '0'. Once I turned off the ignition the above started.
Old Apr 25, 2007 | 07:29 PM
PETE'S_6.0PSD
looks like electrical problem, make sure you battery clamps are not coroded, or you might have fried PCM, do you have Tuner or any aftermarket parts?
Old Apr 25, 2007 | 07:41 PM
zx250's Avatar
zx250
Of the next Riffraff East
Was your battery light on??
Old Apr 25, 2007 | 07:46 PM
BillyPat's Avatar
BillyPat
Truck is bone stock. I did repace the alternator about 1 yr ago.
The Battery light was not on.
