Cable for emissions test missing?
Old Apr 25, 2007 | 09:17 AM
slapshot7's Avatar
slapshot7
Ibought my 97 F250 used. I took it to get a insp. sticker. They said that a cable was cut out to avoid the check engine light from illuminating and it made getting the sticker a hassle. It was located under the dash. Can i fix this?
Thanks
Old Apr 25, 2007 | 12:56 PM
Franklin2's Avatar
Franklin2
The wire feeding the light is a pink/lightgreen. You should be able to hook it back up. You can probably expect it to burn all the time, in which case you will have to put a code reader on it to find out what's wrong. Have you looked over the engine compartment? I am assuming the inspection guys did? How much looks modified under there? I hope it's still fuel injected.
Old Apr 25, 2007 | 03:44 PM
subford's Avatar
subford
Thanks
If it is a 5.8L F-Series 49 states over 8,500 GVW it is not supposed to have one under the dash.
It is still an OBD I and the cable is at the drivers hood hinge on the fender.
Old Apr 25, 2007 | 08:27 PM
Franklin2's Avatar
Franklin2
I thought he meant the wire to the light was cut. If you cut the cable to the scan port, that will not kill the check engine light will it?
Old Apr 26, 2007 | 10:05 AM
subford's Avatar
subford
No I do think so but I was just guessing, as that is what the Inspection Station told him when they could not find the OBD II plug on a 97.
Old Apr 26, 2007 | 12:28 PM
slapshot7's Avatar
slapshot7
The Isptn Station said it was cut and that it would kill the check engine light, but they didnt look elsewhere for the OBD cable. It is a 5.8L so I will check the driver side fender well for the cable. Thanks.
