engine rattle
Old Apr 24, 2007 | 10:06 PM
cobramustangboy's Avatar
cobramustangboy
engine rattle
Alright, I got me a 99 F250 with the 5.4 about 6 months ago. Ever since I got it, it makes a rattling sound at low rpm and then when I begin to accelerate. However, once it gets up to higher rpm it stops rattling. It doesn't seem to be a problem, but its just one of those annoyances. I have opened the hood and tried to find the noise, its almost sounds like the fan is rubbing, but its not. It has a rattling sound like its metal on metal rubbing. The truck is stock, so has anyone else experienced this? Thanks.
Old Apr 25, 2007 | 06:15 AM
torkum's Avatar
torkum
Take your serp belt off and start the engine for a couple of minutes to see if its a external noise.
Old Apr 25, 2007 | 06:39 AM
Joe Finn's Avatar
Joe Finn
My truck has a noise similar to what you describe. It took a while, but I narrowed it down to the forward drivers side Cat. Something inside the cat is "rattling". I'm not going to mess with it 'til it blows out or fails inspection. It's just annoying.
Old Apr 25, 2007 | 07:00 AM
rsylvstr's Avatar
rsylvstr
another thing to check, although the sound you describe seems different, is the manifold studs....see if they are all there.
Old May 17, 2007 | 11:01 PM
gryc's Avatar
gryc
I have a '99 4.6l that had a rattle as well as a leaking head gasket, passenger side no less. I replaced gasket and also found the timing chain guides were worn to the metal which caused a rattle sound. After replacing there is no noise and a remarkable amount of power gain.
genscripter
May 1, 2015 02:00 AM
truckfella
Modular V10 (6.8l)
Oct 25, 2013 05:45 AM
avox
1983 - 2012 Ranger & B-Series
Oct 25, 2009 11:47 AM
travlnman
3.8 & 4.2L V6
24
Jan 25, 2004 07:44 PM
