Warner 1356 transfer case removal
Old Apr 24, 2007 | 09:19 PM
gglmn's Avatar
gglmn
Looking for tips on reaching the 6 bolts hold the transfer case to the transmission. I don't have the truck on a lift and I'm having a hard time getting to the upper bolts.
Thanks,
George
Old Apr 24, 2007 | 10:09 PM
dhag911's Avatar
dhag911
if i remember right i had to use a wrench couldnt use the socket took me about 10 minutes in the garage no lift either then i just slid right out get another person to help you get it out its not that heavy just that you are in an ockward position without a lift. everything was fairly simple
Old Apr 25, 2007 | 09:02 AM
Bear1_301's Avatar
Bear1_301
My 91 has 6-13mm bolts. I used a wrench on the top bolts?
