Does anyone know of a place that I could find a set of four wheels that came on the 92-96 F150? I would like to replace mine with the same kind that came on my 95. Mine are getting really bad with alot of rust down inside the wheel. Here's a picture of what my wheels look like. Note the picture was taken 7 years ago.
You might ask around at a body shop, or a tire & wheel shop, too... some guys trade their old wheels in when they switch them for new tires & wheels. But the scrap yard is probably your best bet. I've seen all sorts of original wheel types in the boneyards.
Yeah those ones are common for rusting maybe get some rims like mine 10 hole or the other ones i forget i think they are 12 hole im not sure same holes but spread out pics are in gallery
If you buy aftermarket wheels make sure you have them run out on a balancer before you mount tires on them. Some of them are out of round pretty bad. I bought 4 from Summit a few years back and ended up sending 2 of the 4 back. It wasn't a problem and they replaced them at no cost.....just the time.
Next time I'll spend a few extra bucks and buy from a local shop so they can hopefully find 4 good ones.
Nothing like an OEM wheel.....
Good Luck
