Sponsored by: Auxito
Upper Air Intake, Please help!
Old Apr 24, 2007 | 05:18 PM
a64armt's Avatar
a64armt
Ok, I have managed to damage my upper air intake manifold for my NA 5.4 in my Expedition.
I had just started receiving the P0401 code, Insufficient EGR flow. I decided to check the voltages and such, no issues. Ok, I will check the EGR passages for blockages................................:shrug:
When I went to loosen the rear EGR valve bolt, I cracked the "ear" in the upper intake manifold where it mounts. :xpl: I wanted to vomit when it happened. Even worse, the broken piece fell under the intake manifold and I can't seem to "fish" it out. What a pain.
So, what started as a simple check engine code, is now an upper air intake issue. Joy!
Ok, I removed the upper air intake and I have considered new part, initial search yields the cost can be $800. Ok, I will check for a shop to repair via weld or weld a stud so I can mount the EGR valve. Another option is to look for a used upper air intake being sold by someone far more ambitious than I who has installed a supercharger.
The last option was to search for an aftermarket, or performance upper air intake. I have seen a few on E-bay with larger throttle body's for about $250.
This is not a performance vehicle what so ever, it is a 1997 5.4 4x4 Expedition with 165,000 miles.
Any ideas, suggestions, or even parts for sale?
Additionally, I am headed back to Iraq in a couple of weeks and I was hoping to have this solved before I leave so my wife can drive the truck. So, time is short. Subsequently, I have posted this on a couple of sections hoping to get a quick response, or even catch someone selling the part I require.
Thanks in advance.
Vincent
Old Apr 24, 2007 | 05:26 PM
pronstar's Avatar
pronstar
I'm not aware of any performance intake manifold for the 2-valve 5.4...?
Only the 4-valve 5.4
I think getting a shop to weld the repair will be the fastest, most cost-effective solution for your problem.
Old Apr 24, 2007 | 05:50 PM
a64armt's Avatar
a64armt
5.4 intake
I believe you are correct, upon closer inspection, all upper intake plenums or manifolds are for the 4.6, I guess for Mustangs.
Thanks for the quick reply. I will look for a weld shop tomorrow.
What a pain.
Thank,
Vincent
